1994 honda accord fuel issues help
i have a 1994 honda accord lx 2.2 lets see ive replace the distributor ,fuel pump cleaned injectors ,battiery post,replace main relay, cleaned theair control valve but if i take carb cleaner and spray in the intake she will run so i know its fuel what ya ll think
You should check mechanical timing just to be on the safe side. If it's fine, you should pick up a fuel pressure tester from Harbor Freight just to see what fuel pressure actually looks like. If it's above 35 or so then you should get a noid light and check that the injectors are all pulsing. It's not too common but it is possible the ecu is bad.
When I needed a fuel pump, I replaced it.
Then had so many problems.... Diagnosed with every fuel problem...
Just to find out I had a faulty fuel pump. CarQuest.
And AutoZone, O'Reilly, NAPA and Advanced Auto ALL said "we never sold it to you." Funny, when I took it back and showed them my receipt from my Wells Fargo .com ...
May be a faulty new part
dslatet455
Mar 15, 2018 10:18 PM
musikpal
Mar 26, 2010 06:08 AM
