92 Cam Seal replacement and Keyless/Alarm Install
I am the new owner of a 92 EX 5-speed that will be a commuter car. I need to install keyless in it. Can anyone give me a good source for a wiring diagram that would help me with this install?
Also, what is involved in a Cam Seal replacement?
This is for auto starters:
Function- Vehicle Color - Location
Start: - BLACK/WHITE - IGNITION SWITCH HARNESS
Ignition #1: - BLACK/YELLOW - IGNITION SWITCH HARNESS
Ignition #2: - YELLOW - IGNITION SWITCH HARNESS (HEATER)
Accessory: - WHITE/BLACK - IGNITION SWITCH HARNESS
Brake Light: -GREEN/WHITE (+) - AT SWITCH,BRACKET ABOVE PED BRACKET
Tach Signal: - BLUE - AT DISTRIBUTOR OR DASH FUSE BLOCK
Parking Lights: - BLACK/RED (+) - HEADLIGHT SWITCH OR AT FUSE BOX
Headlights: -BLUE/RED - (-) AT HEADLIGHT SWITCH
OEM Alarm Disarm: - BLUE OR BLUE/WHITE - (-) AT DIS-ARM SWITCH
Key less entry/ alarm wires
Constant +12 Volts: - WHITE - IGNITION SWITCH HARNESS
Starter Kill: - BLACK/WHITE - IGNITION SWITCH HARNESS
Ignition +12 Volts-BLACK/YELLOW -- IGNITION SWITCH HARNESS
Dome Lights/Superv: BLACK/WHITE (-) -BROWN CONNECTOR ABOVE FUSE PANEL
OEM Horn: - BLUE/RED OR GRAY- (-) STEERING COLUMN HARNESS
Power Lock: - BLACK/WHITE - DRIVER KICK PANEL, 2 PIN PLUG TAPPED
Power Unlock: - BLACK/RED - TO HARNNESS ABOVE FUSE BOX *
Alarm Input Wire: - BLACK/WHITE (-) - BROWN CONNECTOR ABOVE FUSE PANEL
*Negative Pulse Door Lock System
Is this what you were looking for?
[Modified by Stew Pidasso, 12:36 PM 11/8/2002]
