asr sway bar help
Hello all, I recently installed the following on my 94 civic hatch; f7 lca, asr subframe brace, asr sway bar and koni/gc kit.
The problem I'm having is that when I jack up the driver side only i cannot adjust the sleeves due to the pressure of the sway bar. However when I only jack up the passenger side the spring is just sitting loose and i can adjust by hand without jacking up the driving side. Any ideas on what can be causing this?
ilvi3tkidxx
Feb 27, 2009 01:24 AM
