Classic Hondas All Pre-1988 Hondas.
Wierd high idle
Old Aug 28, 2016 | 07:06 PM
Granulatedsugar's Avatar
Default Wierd high idle
I drove my crx with a d16a1 in it for the first time today. I didn't drive It above 3000 rpms. It ran perfectly. Then later tonight I took it out to see how fast it could go and reached about 7000 rpms. When I went to slow down, it stayed at 3000 rpms and wouldn't go down. I turned off the car and checked the throttle cable. That wasn't a problem. I started the car again and drove it home just fine. I didn't go above 3000 rpms again and it was fine. Anyone have a clue of what this could be?
Old Aug 29, 2016 | 07:16 PM
NSelection's Avatar
Default Re: Wierd high idle
Maybe check all your vacuum lines for a leak.
Old Aug 30, 2016 | 05:16 AM
I quickly went over all the vacuum lines and nothing. The wierd part is that it only does it in gear after I up shift. It usually stays at high rpms. And if I down shift and slow down, it brings my rpms down and then back to normal.
96delsol123
May 30, 2015 06:18 AM
wcsh86
Aug 4, 2006 11:18 PM
explictness
43
Feb 17, 2006 02:37 PM
CrxSi707
Apr 5, 2004 10:04 AM
G$
30
Oct 11, 2001 06:18 AM
