Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2015 Civic possible ignition problem,
Old Aug 28, 2016 | 11:14 AM
GeROD's Avatar
Default 2015 Civic possible ignition problem,
This morning I drove my car to work. I turned off the motor when I arrived, but had to move to another parking spot about 5 minutes later after and the it would not start. All the electronics in the car worked just fine, but gave it a jump start anyway, and the car started just fine. Took the battery in the get it checked later that evening at Autozone and it tested normal. Any ideas what could be causing this to happen? Gave me the same trouble about 5 days later.
Old Oct 5, 2016 | 10:29 PM
Hyudryu's Avatar
Default Re: 2015 Civic possible ignition problem,
Get a voltage meter and measure the voltage of the battery when the car's off. It should be around 12.6. If it's lower than that, then either your battery isn't holding a charge, or the alternator isn't charging it. Now measure the voltage with the car running. It should be reading a little above 14v. I've seen people complain about the battery dying on their 9th gen civics
bopbop93030
Jan 11, 2012 09:56 AM
DKYamada
Aug 31, 2009 07:51 AM
this_guy07
Nov 14, 2008 03:11 PM
ekhatch9
11
Mar 4, 2007 08:48 PM
sharkey65a
Feb 15, 2003 03:53 PM
