Wagon Rotors upgrade
Old Aug 26, 2016 | 04:37 AM
angrysmileyface's Avatar
Default Wagon Rotors upgrade
So Ive been looking through the forums and have found several writeups on how to do HOR to ROH upgrades on what appears to be sedans and coupes. I know certain 98/99 Acura CL parts fit, but what I guess Im asking is: What hubs do I specifically need to do this conversion since I already have the large wagon rotors and calipers. Do I need CL3.0 or 2.3 rotors and hubs to avoid replacing my calipers?
Thanks.
Old Aug 26, 2016 | 07:55 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Wagon Rotors upgrade
3.0L CL will have the larger 282mm rotors you want for the wagon conversion.
Old Aug 26, 2016 | 08:22 AM
Sounds like a plan then, The wagon's bearings should be able to do the 3.0CL hubs correct?
Old Aug 26, 2016 | 12:29 PM
MAD_MIKE's Avatar
MM Gruppe B
I believe so, the following vehicles share the same front wheel bearing.
90-97 Accord Wagon
95-97 C27 V6 Sedan Accord
95-98 Odyssey
97-99 CL 3.0
Old Oct 14, 2016 | 12:49 PM
Have been looking and unable to make a determination on this, but what is the difference between the 3.0 wheel hub and the 2.3L hub? Will the 3.0 rotors fit on a 2.3L hub? I have a hub and bearing off a 98 3.0L and am considering going back to get the other side, however everyone always talks about the 2.3L hub in the swap pages.
S3_EN
Suspension & Brakes
Jul 17, 2017 03:09 PM
thehondalyfe
Sep 14, 2015 04:49 AM
fwd0wns
Aug 3, 2012 08:29 AM
sony224422
Dec 10, 2007 03:20 PM
m0t0rhead
Apr 27, 2005 03:43 PM
