Stripped header nut. Ideas/help?
Old Aug 25, 2016 | 10:48 AM
B20VtecVillain's Avatar
Default Stripped header nut. Ideas/help?
So I'm doing my head gasket on the B18C/DC2 daily and I have one damn nut on my exhaust studs that is stripped. Because of my header style, RMF narrow, I don't have enough space from the primary to get a socket on there either normal or strip nut socket, only wrenches. A standard 12mm wrench just slips, as does a small adjustable wrench I tried. Channel locks are going to be my next attempt but again space is limited. I also soaked it in WD Specialist to try and help break it loose and make it easier. Any ideas what to try next? This one damn thing is holding me up lol, head is disassembled, cams are out, ready to pop the fuel line and pull the head & intake mani as soon as this one damn header nut gets off.
Old Aug 25, 2016 | 08:45 PM
civic-steve-94's Avatar
Default Re: Stripped header nut. Ideas/help?
Try using a standard or sae however you want to refer to it. 7/16 is close. Also I'm assuming your using a 12 point wrench try and fine a 6 point or using a tubing wrench in 12mm.
Old Aug 25, 2016 | 09:30 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Heat (torch) will expand the nut hole and may help it break free easier.
Old Aug 26, 2016 | 10:35 PM
PyroProblem's Avatar
Pics?
Cut the head off?
The header but is stripped on the hex flats? Not the threads right?
Have access to a Welder?
Old Aug 27, 2016 | 04:58 PM
Originally Posted by PyroProblem
Pics?
Cut the head off?
thanks for all the tips guys I tried all sorts of methods but in the end I just cut it off with my Dremel and bought new stainless exhaust studs all the way around. I had already bought extended stainless intake studs because I added a thermal gasket and needed the extra thread in a few locations anyway, so I just bought another set and replaced the exhaust side too. Luckily a pair of vice grips is all it took to remove all the studs. Everything is now cleaned up, intake manifold runners, plenum, intake ports on head all cleaned and smoothed, exhaust ports cleaned. ARP head studs in the block. Put the intake and thermal gasket back on my head. Tomorrow morning the head goes back on the block and everything gets put back together finally. Will be so happy to drive the car again. I actually found the slight head gasket leak while tuning the car, so I'm going to do a few more pulls now when I'm done to make sure nothing needs changed, but I made almost 200whp with a stock B18C short block and the leaky head gasket lol.
paowa
Jun 23, 2007 01:52 PM
Jdmglenn
Jan 31, 2005 09:50 AM
Project_ED8
Mar 10, 2004 11:36 AM
tuan...
Feb 27, 2004 03:20 PM
JSTOCK
Oct 16, 2002 06:20 AM
