GSC turbo cams installed advice needed
Old Aug 22, 2016 | 01:02 AM
Pullig's Avatar
Default GSC turbo cams installed advice needed
Im looking to get some outside advice ive done everything ive known possible to remedy an issue I am having.
setup is this b18c forged flat top cp pistons eagle rods, type r head with ferrea 100lbs springs and ferrea valves. edelbrok intake manifold
GSC Turbo cams Degreed in plus 3 deg exhaust minus 3 intake
ngk 7 resistor plugs gapped .020 110octane on NEPTUNE
go-autoworks pro ram horn kit with 62mm turbo
Motor was prev tuned on stock type r cams around 30lbs of boost
added these cams and no im getting a strange misfire hesitation at low vtec enagement vtec engagement anywhere from 4500-5800 misfire hesitation vtec set at 6k runs good and hard boost isn't crazy 11-14lbs
I had vtec set on my type r cams at 5k no problems
afr is 11.7 during this issue and it happens no matter if I partial throttle engage or full throttle engage
im still on stock ignition setup
Old Aug 22, 2016 | 01:05 AM
Pullig's Avatar
Default Re: GSC turbo cams installed advice needed
ive tried pulling 5deg of timing out of the area this is happening no change.... ive added 4 deg no change im at a total loss on this
Old Aug 22, 2016 | 03:59 AM
LightningTeg's Avatar
Community Builder
You probably shouldn't be arbitrarily throwing 4 degrees of timing at it unless you are reading plugs or on a dyno. Good way to blow the motor.
This is tuner issue. curious why you have the cams not at 0 - 0?
Old Aug 22, 2016 | 04:17 AM
Javcolin's Avatar
As far as i know, and i just bought a set of GCS's they are drop in, no degree needed, actually there is a post from The Shodan, that shows a video with the cams set to 0-0 and a video with some sort of dedree on them. and you see a big diference, from one and the other.
Worth having a look at that post.
Old Aug 22, 2016 | 04:36 AM
TheShodan's Avatar
Moderator
Correct. These need to start of at 0,0 unless the head/block had been milled to adjust for that change. They shouldn't be at the settings that they are at initially. That can cause a big problem.
Old Aug 22, 2016 | 05:02 AM
Pullig's Avatar
Head and block has been milled. It's been sleeved. Also I know how to read plugs. Another thing this isn't happening at any type of boost pressure Plus I'm on race gas. I'm not too worried for short duration Not like I'm beating it too hell. Like i said it does this at partial throttle engagement.
I degreed the cams exactly where the spec card said to place them.
Old Aug 22, 2016 | 05:10 AM
Pullig's Avatar
Also having to take a car to a dyno and it not being ready because of mechanical or electrical issue is not something I want to. Which is why I messed with timing trying to figure out if I could get some type of improvement.
The motor is sound mechanically. 170-180psi comp across the board. Runs rather well beside the issue I have described
Old Aug 22, 2016 | 07:30 AM
TheShodan's Avatar
Moderator
The misfire is what's sticking out to me. I'd check for the ignitor/distributor setup. I know it may be stock, but here, I'd look into adding in some digital ignition and external coil to enhance the stock system without resorting to coil-on-plug, which may be much more outside any budgetary concerns.
Old Aug 22, 2016 | 10:20 AM
Dark_Teg's Avatar
A lot of times issues at part throttle that cant be tuned out are TPS related. Your sensor could have a dead spot.
Old Aug 22, 2016 | 10:41 AM
TheShodan's Avatar
Moderator
I would only concur if they are using some sort of after market TPS or the wires are somehow compromised. I've never seen random misfires from Denso TPS sensors. I'd look at the area of "spark" first before going to the TPS hardware. If the TPS is off, then that's more software related, which means more than likely that the issue is surrounding the area that is more tuning related. you know?
Old Aug 22, 2016 | 11:14 AM
Dark_Teg's Avatar
Sometimes an engine bogging down is misconstrued as a misfire is what I was getting at, but you are probably correct.
Old Aug 22, 2016 | 03:35 PM
Pullig's Avatar
Stock type r throttle body with stock tps. Already went through full range of motion no issues. Like I said moving vtec 6k or higher completely fixes the issue. Honestly timing and fuel is very similar between 4800 and 6k Even fuel.
I already have icm delete and digital ignition setup sitting in some boxes ready to go on. Just didn't want to complicate this situation. I may try to put the cams at 0 - 0. But didn't want to just go moving them around when It's safe now.
Old Aug 22, 2016 | 05:22 PM
wshuculd's Avatar
Put it on the dyno. My gsc cams are set at 0. Your tuner needs to spend some time dialing in the cams. When mine was breaking up I put a new igniter in and fixed the problem
Old Aug 22, 2016 | 07:30 PM
Pullig's Avatar
well it could very well be an igniter issue. But I just find it hard to believe when it ran just fine before cam install. At this point I'm not trying to make the most power or be optimal. I just want the thing to run right that way I'd feel more comfortable before spending time and money on a dyno.
Old Aug 22, 2016 | 08:20 PM
TheShodan's Avatar
Moderator
It's also more about reliable/repeatable power. You more than likely need to see about the igniter and for your tuner to check timing via the software, not physical.
Old Aug 23, 2016 | 03:48 AM
Community Builder
The sudden change in VE could be blowing out the spark. My buddy had the same problem on his old distributor and Pro 1s
Old Aug 23, 2016 | 09:54 PM
Pullig's Avatar
man I hope so. I guess the next course of action will be to install icm delete with the Mallory dig 6 see what it does
Old Aug 26, 2016 | 07:13 AM
TheShodan's Avatar
Moderator
I'd do that anyway.
Old Sep 7, 2016 | 08:19 AM
Pullig's Avatar
Just to update. Upgraded Ignition setup installed with icm delete.
1. Problem is still there exactly the same issue as before.
Decided to do a test advance intake cam in 2 deg slightly better
so I'm assuming it's going to be cam position related
Issue 2.
I did not wire the tach output from ignition box Tach works ecu reads rpm
but have an issue in the upper rpms where the tach is dropping out
do I have to wire in the tach output wire?
In all the times I've dealt with digital boxes, I always had the tach output wired up. I'm not a wiring specialist, but from working with some people on these, yes. Hook those up.
As for the camshaft timing relation, it's more than likely you weren't at theoretical 0,0. But did you change timing via the software as well?
Old Apr 25, 2021 | 07:16 PM
Pepe14's Avatar
5 Year Member
Loved
Community Favorite
Issue 2.
Youre probably not active anymore but any resolution to the issue?
Old Apr 25, 2021 | 07:43 PM
Pullig's Avatar
Vtec is just set too low with my ram horn smallish 6262 turbo setup. Raised vtec to 6k rpm good to go. You could probably lower vtec with a larger turbo and bettter top mount manifold.
EGcivic_95
Jan 8, 2012 11:54 PM
GreenVillian
Nov 12, 2002 11:32 AM
CimorelliCRX
Aug 31, 2002 03:20 AM
Juelz Santana
Apr 30, 2002 03:48 PM
MysteriousGSR
Apr 15, 2002 06:47 PM
