1992 honda accord e85
Hello I am looking at going with e85 for my 1992 Honda accord just wondering a couple things like what size injectors would be recommended and what a good size of fuel line would be.
I have the following done to my engine
it is a f22a6 block SOHC
I put darton sleeves in the block bored out to 86mm
I have arias 9:1 86mm pistons and h beam rods with a higher floating wrist pin coated dome and side skirts
turbonetics hurricane turbo
aem stand alone ems
electronic boost controller
Bisimoto 2.4 turbo camshaft
titanium springs and retainers.
ram horn exhaust manifold
custom intake manifold
adjustable cam gear
I will be using the car for drag racing and will be running 20lbs of boost what size injectors should I go if I go with e85 also will a 320lpm e85 intake fuel pump be enough to to feed the injectors and what would be a good size for the fuel lines.
Thanks
aem stand alone ems
adjustable cam gear
Thanks
