No crank no start help!!
Old Aug 19, 2016 | 06:54 PM
Reckless_habits's Avatar
Default No crank no start help!!
Ok guys so i have a 94 ej1 it was an automatic d16z6 with vtec but i swapped to a manual d15b7 no vtec and the parts car i used was a 94 civic sedan with no power windows and no sunroof or power mirrors since my ej1 harnes was different i went and got the harness from the sedan and swapped it out to my ej1 and i used the same fuze box from my ej1 with the harness of the sedan and some connections had wires located different and i still put it on so i go and try to turn on the car i can turn the lights on in the car like the dash and other stuff some stuff works when i try to turn it on i can hear the fuel pump and everything but when i put it to the position to turn the car on nothing happens they key just turn i know is not the battery or something like that because the light dont turn off in the dash or dim so anyone can help me out here what could i do to fix this problem i really dont know much about all of this wireing and stuff like that
Thanks..
Old Aug 19, 2016 | 07:37 PM
Former User's Avatar
Default Re: No crank no start help!!
Let me respectfully introduce you to two useful writing tools:
1) The period: A punctuation mark (.) used at the end of a sentence.
2) The carriage return: A control character used to reset a device's position to the beginning of a line of text.
Please use both tools to make your post readable.
Old Aug 20, 2016 | 05:33 AM
mk378's Avatar
It is not typical to change harnesses in an auto to manual conversion. All you really needed to do electrically is bypass the neutral switch (on the shift lever, prevents starter from working unless in P or N), extend wires for the reverse lights (auto-- switch is on the shift lever, manual it is on the transmission), and swap the ECU. The harness plugs for parts you no longer have in the car-- transmission solenoids and VTEC-- can be left unplugged.
silez
May 1, 2014 03:55 AM
chrisaddition
May 25, 2012 07:59 AM
cxhatch93
Mar 6, 2011 02:09 PM
Yeah Daybid
Apr 3, 2009 09:46 AM
Import_spoon
13
Feb 28, 2008 10:29 PM
