1995 Civic will not start. Does not turn over. Fuel pump primes.
Old Aug 16, 2016 | 03:41 PM
Hegro's Avatar
Default 1995 Civic will not start. Does not turn over. Fuel pump primes.
Car is a 1995 Honda Civic DX. Within the last 15k miles it has a new starter, alternator, battery, plugs, wires, cap, rotor, etc.
Left work today and my car was on empty. Drove to the gas station and filled it up. Started right up after getting gas and I drove to the grocery store. Came out of the grocery store and it would not start. First thing I checked is the little plastic plunger on the clutch that wears out. It was broken! Wooo easy fix. I pop the one off of my brake pedal and move it to my clutch. No luck. Still will not start.
The fuel pump primes when the key is turned over and all of the dash lights illuminate as they normally would. I checked on the starter quick in the parking lot and the ground and everything seem to be connected normally.
Should be unrelated but I also have my driver airbag out at the moment as I was in the middle of swapping out my combination switch but cannot remove the steering wheel bolt. As I said, shouldn't be related but just trying to be as thorough as I can be.
Thank you.
Old Aug 16, 2016 | 03:48 PM
Former User's Avatar
Default Re: 1995 Civic will not start. Does not turn over. Fuel pump primes.
There are two stoppers (high and low) on the clutch pedal. Which did you replace?
Old Aug 16, 2016 | 03:53 PM
Outrun's Avatar
Try jumping the clutch interlock connector with a paperclip. It's kind of hard to reach (I am on the husky side) for some people.
Old Aug 16, 2016 | 04:13 PM
Hegro's Avatar
Damn, I have replaced the upper plunger multiple times on different cars. Didn't even realize the one I was looking at in the parking lot was the bottom one. It wasn't completely broken but was juts kind of hanging in the hole. I ripped it out and assumed that was the issue. I slapped the one extra stopper I had on the bottom one when I got the car home. Just looked at the upper portion and there is no stopper. I am assuming this is the issue. Will go down to Honda first thing in the morning and pick one up. Does anyone know if this is something dealerships carry? I would assume yes as it is a higher wear item.
I realize I can glue a penny on there but I would rather just go get the part, thank you.
Appreciate the help. Will update if this is not the issue.
Old Aug 16, 2016 | 04:14 PM
Just move lower stopper to upper hole. Fixed!
(the lower hole is for cruise control, which I assume your DX lacks)
Old Aug 16, 2016 | 04:16 PM
Hegro's Avatar
Does the lower stopper do anything? There would be a gap between the bolt and the metal portion where the plunger attaches.
Edit: haha I responded before you edited. Will go try it out and update!
See my edited response above.
Old Aug 16, 2016 | 04:30 PM
Hegro's Avatar
​So the last car I did this on was my 1991 hatch and I don't remember it being this difficult. The 5th gen civic has like a metal enclosure around the area I need to get to. Any tips to do this without removing everything? I really really do not want to do that.
Old Aug 16, 2016 | 04:33 PM
Removing the driver's seat, lower cover, and knee bolster may help.
Old Aug 16, 2016 | 04:45 PM
Hegro's Avatar
Haha, yeah I didn't want to do all of that which is what the issue is. If anyone comes across this thread trying to replace the little stopper I remembered what I did last time that helps make it easier. Duct tape the stopper onto a long flat head screwdriver and carefully maneuver it into position. Makes it infinitely more easy as long as you have a good flash light and can see what you are doing.
Thanks for the help RonJ, problem fixed.
Old Aug 16, 2016 | 04:49 PM
Great!
Tim2179
Honda Civic (2001 - 2005)
Dec 9, 2010 12:18 PM
99ssinoc
Aug 26, 2009 08:32 PM
Maness
18
Feb 4, 2009 12:52 PM
rtdillon
Nov 9, 2005 08:49 PM
sloweh3
Jun 7, 2004 05:33 PM
