94 Civic - starts and then stalls
Old Aug 16, 2016 | 11:46 AM
Whiteout9085's Avatar
Default 94 Civic - starts and then stalls
My 94 civic starts then dies and then try and again and runs perfect does anyone know what might cause this
Old Aug 16, 2016 | 11:51 AM
fcm's Avatar
fcm
Old Fart
Default re: 94 Civic - starts and then stalls
Check PGM-FI Main Relay, a common problem... Main Relay Fix and Troubleshooting (Honda, Acura) 94
Old Aug 16, 2016 | 01:07 PM
Former User's Avatar
Also post all CEL codes.
Does the engine idle at spec when fully warmed up?
Old Aug 16, 2016 | 04:41 PM
There is no cel codes light isn't on idle is normal and everything it was doing something like this when I replaced the fuel pump main relay and it was fine til a week or so ago
Does the CEL work?
Old Aug 16, 2016 | 04:46 PM
Im assuming so because when I turn the ignition on it lights up and goes off
Old Aug 16, 2016 | 04:51 PM
Sounds good.
What engine? Any car mods or is it bone stock?
When was the last ignition system tune up?
Old Aug 16, 2016 | 04:52 PM
Its got the d16z6 and has full exhaust with headers and a 5spd tranny
Old Aug 16, 2016 | 04:53 PM
94 Civic EX? Originally auto?
Old Aug 16, 2016 | 04:58 PM
Default Re: 94 Civic - starts and then stalls
Yes to the ex no to originally auto
Old Aug 16, 2016 | 04:59 PM
Why did you replace the main relay and fuel pump?
Old Aug 16, 2016 | 05:26 PM
mk378's Avatar
After it starts and then stalls, don't touch the key. Watch if the oil and battery lights come on like they should any time the key is on but engine is not turning. If they aren't on but you can jiggle the key to make them come on, ignition switch is bad.
Old Aug 16, 2016 | 07:47 PM
Fuel pump was going bad and would work sometimes and the main relay was replaced cause it was not start sometimes after I drove it took the relay out and it was burnt up in some places. Sorry tool me so long I work second shift and don't get off til 230am
Old Aug 16, 2016 | 08:03 PM
So is it possible that replacing the pump and relay did not actually fix the original problem?
Old Aug 16, 2016 | 10:41 PM
Now that I think about it when this started happening was right after I took my intake off so maybe didn't hook it back up or missed something cause it was dark
Old Aug 16, 2016 | 11:08 PM
OK so just got home and got in the car went to crank it and started then died didn't touch the key and only thing that stayed on was the radio
Old Aug 17, 2016 | 07:14 AM
That's a bad ignition switch, which was also likely the original problem when you replaced the pump and relay (unnecessarily).
Old Aug 17, 2016 | 08:12 AM
How much of a pain is that going to be to replace
Old Aug 17, 2016 | 08:19 AM
Not difficult.
Old Aug 17, 2016 | 08:24 AM
Not difficult.
OK I have never done it before
Old Aug 17, 2016 | 09:14 AM
mk378's Avatar
You just need to remove the plastic "clamshell" covers on the steering column and the switch is right there. Two small screws hold it on to the back of the key cylinder. You do not need to mess with the key or the locking mechanism itself. The wires from the switch go down under the dash and plug in to the fuse box and maybe something else. As with any electrical work, disconnect battery first. That is especially important here to be sure the air bag does not go off by accident.
Old Aug 17, 2016 | 09:36 AM
Yea my SRS and abs lights are on so if they deploy I'd be like wtf lol
Old Aug 17, 2016 | 11:07 AM
slomofo's Avatar
GDD Member
Old Aug 17, 2016 | 11:10 AM
Originally Posted by slomofo
Lol Yea they were on when I bought the car earlier this year so slowly trying to right the problems one at a time
earbie
Jan 24, 2017 07:43 PM
Einhander276
Jan 15, 2013 08:11 PM
civicracer94
14
Aug 17, 2010 04:45 PM
team2dcrx
Feb 2, 2008 06:55 PM
