Mysterious wobble in crank pulley (new pulley still wobbles)
Old Aug 15, 2016 | 09:49 PM
mrowxlived's Avatar
Default Mysterious wobble in crank pulley (new pulley still wobbles)
2000 honda accord se 2.3l automatic (f23a1). After two crank pulleys, doing the timing belt twice, replacing the accessory belts, and checking specs on everything.... still an intermittent wobble in the crank pulley. Sometimes it's bad, sometimes not as much, sometimes not at all. This is driving me nuts. The bolt is on very tight, no other pulleys are wobbling or shaking, and sometimes it doesn't wobble at all. I have read hundreds of forums on the subject, and they all say the same thing ... replace the pulley/balancer. Well I did, and no difference.
Both pulleys look fine, no cracks, good rubber...
Keyway is fine, so is the key...
What could cause this???? I'm fairly certain the crankshaft is fine. The pulley is not loose. No grinding noises, just a little whine when the pulley wobbles. Any insight would be appreciated!
Old Aug 16, 2016 | 05:01 AM
origamy's Avatar
Default Re: Mysterious wobble in crank pulley (new pulley still wobbles)
Generator's or steering pump's belts are not overtightened?
Old Sep 9, 2017 | 10:54 AM
marshin2's Avatar
I've got the same problem! Swapped the balancer and the wobble is still there! Did you have any luck?!
devilpuppy
Aug 30, 2024 09:15 AM
SeraphimKidd
Jun 14, 2009 09:37 PM
91 luder
May 15, 2009 03:50 AM
bow tie
Oct 17, 2008 01:18 PM
white_panther
Dec 8, 2006 04:47 PM
