Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Clutch Won't Engage
Old Aug 12, 2016 | 01:00 PM
ruccijr's Avatar
Default Clutch Won't Engage
I have an 04 Accord that I cannot figure out why the clutch won't engage. I've replaced both the master and the slave cylinders and bled the system, by hand and with a vacuum pump. The first half of the pedal travel still feels as if there's a bubble trapped somewhere, but after literally hours of bleeding, no air has come out in quite some time. What could be the problem? I have another vehicle that you have to raise the back end of the car after bleeding and bleed again so that the bubbles move around and work free, should I try this? Any help would be greatly appreciated.
Old Aug 14, 2016 | 10:38 PM
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
Default Re: Clutch Won't Engage
It would make more sense to me to raise the front end of the car to let all the air flow upward towards the bleeder screw.
Try it like that, or your way too.
How are you bleeding the system?
Pump about 5 times, hold it, open bleeder screw, allow fluid to come out, tighten bleeder screw, release pedal and repeat?
B_Swapped93
Dec 8, 2013 05:02 PM
autoxthis
Aug 21, 2008 08:56 PM
autoxthis
Aug 21, 2008 08:31 PM
tbuck23
Apr 3, 2007 01:27 PM
iwhichisme
Nov 24, 2002 05:47 AM
