95 Del Sol fog -- lights don't work
hi everyone. i have a question? on my 1995 del sol i replaced the fog lights and they still don't work. is their another problem with them i need some help ive been trying to figure this out for awhile.
First thing to check is whether the bulbs are getting power. I'm guessing they aren't, but you can verify that with a multimeter. If there is not 12v at the lights with the car on and the foglight switch on, then check for 12v at the switch. If there is not 12v at the switch, then check your fuses. Actually, check your fuses first, THEN go from the lights to the switch, etc.
If there is no power at the lights, but there IS power at the switch, then you either have a bad switch or a break in the wires. Just keep tracing power until you find the issue.
Lizardslap
Sep 11, 2013 03:07 PM
MemphisChick625
Oct 3, 2007 07:40 PM
