97 accord IAT sensor
Old Aug 8, 2016 | 02:21 PM
Efabe's Avatar
Default 97 accord IAT sensor
The temp readings from my IAT Sensor are quite a bit higher than the ambient air temperature. Is this simply because of the sensors location in the manifold, or is it malfunctioning? A bench test revealed that at 75 degrees F the sensor has 2.2 Kohms of resistance and at 125 degrees F it drops to 1.0 Kohms...if that helps
Old Aug 9, 2016 | 12:01 AM
holmesnmanny's Avatar
Default Re: 97 accord IAT sensor
Those are normal readings. It would test around the same as temp readings for the coolant temperature sensor. If you pushed it up to 175f it should be around 180-250 ohms.
jerryliedtke
Sep 21, 2014 09:25 AM
xasiansupermanx
Nov 5, 2007 08:23 AM
poysenrock
Dec 17, 2006 03:12 PM
treeguy
Apr 3, 2005 11:58 AM
