2008 Pilot charging light blinks off and on.
Old Aug 5, 2016 | 07:19 PM
whattayaknow10's Avatar
Default 2008 Pilot charging light blinks off and on.
My 08 Pilot had alternator problems, changed it with a "new refurbished'. The charging system light comes on, but the battery is charging, tested it with a voltage charger, it was at 14.10, then with everything on 13.87-14.01. I spoke to the company that sold me the part and they said to reset the system. What would i reset? unplug the battery?
Old Aug 6, 2016 | 11:24 AM
fcm's Avatar
fcm
Old Fart
Default Re: 2008 Pilot charging light blinks off and on.
A flashing Alt. warning light is a symptom of worn brushes or brushes that are not seating properly.
To "reset" anything on your car all you need to do is disconnect the batt,. [neg.(-) terminal for at least 15min. overnight is better, keep in mind clock and radio tuning will reset and if your radio is "coded" you will need to code to re-enter it, this will also reset the ECU and will take a few miles of driving to "re-adjust". 94
Old Aug 6, 2016 | 01:45 PM
holmesnmanny's Avatar
parts store alternators can be dead out of the box, even if charging fine, the best bet is to either get a Denso or a major brand name
M3THTICAL(EF)
May 4, 2015 06:05 PM
88hondaspeed
Jun 14, 2011 09:34 AM
rattlecannedEF
12
Apr 2, 2009 06:53 AM
idontknowwhatimdoing
Jul 31, 2007 06:01 PM
return_2020
Aug 27, 2005 07:07 PM
