Canīt log more than 5k
Old Aug 5, 2016 | 11:07 AM
Roy Leyva's Avatar
Default Canīt log more than 5k
Anyone know why i canīt log more than 5k on Crome, even if i rev at 7k.
thanks
Old Aug 5, 2016 | 05:41 PM
Muckman's Avatar
Moderator in Chief
Default Re: Canīt log more than 5k
Could be interference. Are you using resistor spark plugs?
Old Aug 6, 2016 | 11:30 AM
GhostAccord's Avatar
Is this a VTEC engine? What is your setup?
Could be that this is the low cam map, have you looked at the high cam map?
Old Aug 7, 2016 | 10:41 PM
VegasInvasion's Avatar
I'm Huge In Japan
turn on smart tracking, it'll automatically switch you to the vtec map. make sure you read the manual in my signature.
Old Aug 8, 2016 | 06:59 AM
Roy Leyva's Avatar
Muckman: I dont know if NGK BKR6e uses resistor or not, but those are what i use. But i was thinking about interference because at high rpm afrs logs richer than wideband samples.
GhostAccord: Is a ZC non vtec engine and im using P30 (vtec map) with vtec option non active.
VegasInvasion: I use low cam map only, is a non vtec engine.
Old Aug 9, 2016 | 05:06 AM
Masterl1nk's Avatar
Are you using hondata s300? Did your datalog file shows more than 5k RPM?
Old Aug 9, 2016 | 06:33 AM
Roy Leyva's Avatar
Crome Pro
MatthewMenze
Engine Management and Tuning
11
Sep 30, 2013 06:16 PM
boogienights
Oct 9, 2010 05:58 AM
Coutts
Jul 16, 2010 12:36 AM
boostedeghatch
10
Jan 24, 2009 04:21 AM
Metal Head
Jun 8, 2006 11:19 PM
