92 accord rear toe adjustment??? 3 degrees???
Old Aug 3, 2016 | 04:03 PM
MrMykl's Avatar
Default 92 accord rear toe adjustment??? 3 degrees???
Hi, my 92 accord was hit by a street cleaner, and since they won't admit it and fix it, it's on me...It was parked and hit from the drivers side into the curb. The DS rear tire is toed in 3 degrees. I've replaced everything to stock except the knuckle with no change. I have seen aftermarket rear lower control arms that adjust, but only 2 degrees I think...Camber on the Drivers Side left rear is still perfect, but the camber on the right rear is out. I have purchased aftermarket upper arms to adjust camber, but I'm waiting to see if i can even get the DS rear tire close to straight! Is there an adjustment on the small lower control arm stock? I can't find one. Help! Thanks!
Old Aug 3, 2016 | 11:11 PM
holmesnmanny's Avatar
Default Re: 92 accord rear toe adjustment??? 3 degrees???
If it were me I would pull the rear knuckle from a junkyard car since Honda doesn't appear to sell them anymore.
Old Aug 4, 2016 | 12:10 AM
MAD_MIKE's Avatar
MM Gruppe B
Rear lower front arm has a cam bolt on the crossmember side. You can adjust rear toe there.
Old Aug 5, 2016 | 04:45 PM
PerformanceFirst's Avatar
Yeah, the front LCA has an eccentric inner bolt for adjusting toe. Make sure the mounting hole in the subframe hasn't stretched as well.
B_Swapped93
Acura TSX
Jan 7, 2019 05:10 PM
e.p
Sep 13, 2016 10:41 AM
Fseries22
Aug 19, 2015 05:50 PM
mrboompow
Suspension & Brakes
Oct 8, 2013 08:29 AM
