High Flow cat question
Old Nov 7, 2002 | 11:10 PM
SC0TT's Avatar
Default High Flow cat question
Heres my setup: Injen intake, b16, DC 4-2-1 Header, Stock cat, Greddy mx exhst.
Would there be a big difference if I used a high flow cat? Worth the money?
Thanks for the info-
Old Nov 7, 2002 | 11:26 PM
Frog's Avatar
Default Re: High Flow cat question (cr-tegra)
YES!!!!!!!!!!!!!!!!!!!!!!!!!
Old Nov 7, 2002 | 11:49 PM
kshymkiw's Avatar
Default Re: High Flow cat question (Frog)
High Flow Cat or Test Pipe?
High Flow cat, yes there would be a diffrence. Also it is good for passing say a test where they visually have to see you have a cat.
Test Pipe, this would be my choice to go with, un-restricted straight flowing. a 2.5" test pipe, bloted up to a 2.5" exhaust would be a nice setup for that. 1 draw back, the sensors must be tricked into thinking they are reading the right O2 levels
Old Nov 8, 2002 | 01:41 AM
SkyNex721's Avatar
Hell yeah it's gonna make a difference. And it's worth the money. You have a nice engine. Nice header, and a tight exhaust system. And stuck in the middle of all that is a stock cat. It's over ten years old, probably all clogged up. It's restricting the flow of your exhaust gases. Definitely get a hi-flow cat. Or a straigh pipe. That's what I have. I have a b16, Kamakazi 4-1 header and a custom 2.5" header back exhaust system. I know, I know, your probably thinking Kamakazi??? That was what the car came with. Next month I am putting on a DC sports 4-2-1 SS header.
Old Nov 8, 2002 | 06:30 AM
JALOP B16's Avatar
Default Re: High Flow cat question (SkyNex721)
Your not going to tell the diff unless the one you have now is cloged.
Catcos suck remember that!!!!!!!!!!!!!!!!!!!!!!!
Old Nov 8, 2002 | 06:49 AM
incubus's Avatar
Default Re: High Flow cat question (JALOP B16)
they do? that is the first time I have heard someone say that.
that is what I was going to get. hmmm....
Old Nov 8, 2002 | 07:11 AM
FourthGenHatch's Avatar
Default Re: High Flow cat question (incubus)
Don't listen to him, I have a Catco and that badboy has been in use for more than 6 months and I have no problems. Maybe he got a bad one or something but everyone else I know who has them has had no problems.
[Modified by FourthGenHatch, 4:12 PM 11/8/2002]
Old Nov 8, 2002 | 08:25 AM
SC0TT's Avatar
Default Re: High Flow cat question (FourthGenHatch)
Cool, thanks for the info guys...I'll probably be picking one up this weekend
Old Nov 8, 2002 | 08:49 AM
habib_88's Avatar
I've got a Catco to, I just did it because I was doing the whole exhaust, the stock cat had 164k on it at the time so I was definally a good idea to replace it. Overall it does the job, right now something either on the cat or near it is rattling (probaly a heat shield) and we noticed compared to my stock cat, the catco pipe was EVER so slightly bigger in pipe diameter than stock. Again I don't know how much power its really worth but i'll take it
Old Nov 8, 2002 | 05:50 PM
90civichb's Avatar
Default Re: High Flow cat question (habib_88)
Will putting straight pipe from header to muffler effect the sound? By that I mean will it be considerably louder without a cat? I just bought stock exhaust for my car because it has none... but i didn't get a cat with it! Also, would it cost much to have the stock exhaust run to the cat?
b.t.w. If anyone here has one.. I'll buy it for $20 if it is still in working condition....
Old Nov 8, 2002 | 07:36 PM
CHRIS 1.8's Avatar
I really couldn't tell any difference when I had my straight pipe from my hi-flow CAT that I have now...
Old Nov 8, 2002 | 08:27 PM
MrTodd's Avatar
Default Re: High Flow cat question (B16A1-EF8)
Most hi-flow cats aren't much quieter than a test pipe when your at WOT - but there usually is a slight difference.
I have a catco in mine, and I have no complaints! It works perfectly and I pass emissions with plenty of room to spare. I have heard that carsound highflow cats are pretty nice as well, perhaps better flowing than the catco.
slvrCD7accord
Mar 29, 2010 07:06 AM
DCSportEJ1Civic
26
Jul 16, 2007 12:44 PM
elbprelude
Feb 9, 2006 06:08 AM
_gurusan_
May 5, 2005 12:04 PM
SiRkid
May 6, 2002 01:02 PM
