Help! Sunroof leak issue
I have an 03 EX accord coupe. The sunroof has been leaking but has got worse, right now its leaking through the sunroof and going down the a-pillar to the floorboards. Specifically to the passenger side. Anyone else encountered this issue or have any ideas for a fix?
Thank you in advance!
Theres a TSB 03-037 on on how to fix this but you could check to see if your sunroof drains are leaking. Or your sunroof seal. I check those first if those check out Good. Then i would follow the TSB. To fix the issue
