D16Y8 swap into 00 Civic - need help with vtec wiring
Old Jul 31, 2016 | 05:41 PM
DesertRatCA's Avatar
Default D16Y8 swap into 00 Civic - need help with vtec wiring
i have a 00 civic 4 door with a D16Y7 non V-Tec motor and its shot. but i have a 96 civic 2 door with D16Y8 V-Tec motor. everything seems like it should bolt right up for a swap. the question is can i wire up the V-Tec to the non V-Tec computer or do i have to swap the wire harness and computer. im just trying to do the easiest way possible..
Old Jul 31, 2016 | 06:25 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default re: D16Y8 swap into 00 Civic - need help with vtec wiring
Add VTEC wires to your '00 Civic engine harness, purchase an OBD-2B -> OBD-2A ECU adapter harness, and plug your '96 Y8 ECU into the adapter harness. You may need to alter some wires in the Y7 engine harness in order to make it fit the Y8 engine... lengthen, shorten and change plugs as necessary.
Old Jul 31, 2016 | 06:30 PM
94EG8's Avatar
Seagull Management
You can add the individual wires for vtec to the harness you have now and perform the IACV fix or buy a '99 - '00 Civic EX engine harness for your transmission type and wire in the secondary O2 sensor. You'll also need an ECU from a '99 - '00 EX to match your transmission type, and on that note if you have an automatic you'll also need to swap the trans for a '96 - '00 EX trans.
You can't simply use the engine harness from the donor car as you can see here:
Old Aug 11, 2016 | 07:00 PM
thanks for the info. i have one more question? i have a whole donor car which is a 96 civic D16Y8 VTEC and the 2000 civic is the D16Y7 NON-VTEC if i took the motor, trans,whole engine bay harness and ECU from the 96 and put it in the 00 civic will it bolt up and work just fine
Old Aug 11, 2016 | 07:52 PM
slomofo's Avatar
GDD Member
Yes, but the dash harness is also different. Look at the ECUs, they have different plugs.
hondamoney
Jan 30, 2016 06:39 PM
FRKWOO
Sep 14, 2008 09:00 AM
Eaglekper0046
Sep 27, 2005 09:41 AM
AGENT 99
Aug 9, 2004 02:11 AM
