SIR Cluster dimmer switch........
Old Nov 7, 2002 | 10:54 PM
Frog's Avatar
Default SIR Cluster dimmer switch........
Need a little bit of insight as to how to wire the dimmer switch so I can turn down the instrument cluster lights in my newly installed SIR cluster. The dimmer switch is still there from the new instrument cluster cover, but no wires coming out of it obviously, I just not too sure which wires power the lights.
thanks guys,
Old Nov 8, 2002 | 10:35 AM
Frog's Avatar
Default Re: SIR Cluster dimmer switch........ (Frog)
c'mon somebody must have managed to hook one up....
Old Nov 8, 2002 | 10:51 AM
JoshDM's Avatar
rrribet
Old Nov 8, 2002 | 11:44 AM
EF_LSVtec's Avatar
Default Re: SIR Cluster dimmer switch........ (JoshDM)
Funny thing...I just transfered the old plug to the new dimmer switch and it worked for 2 weeks. I was rewiring my cluster then all of a sudden it stopped working and I had to use the old switch back. In fact the cluster wouldnt even light up if I plug it to the old dimmer switch...I found directions on a site once...let me find it and repost.
Old Nov 8, 2002 | 11:51 AM
EF_LSVtec's Avatar
Try this... http://students.washington.edu/markpaco/sircluster.html
b18c1del
Aug 22, 2009 01:25 PM
93Civic_hb
Apr 4, 2008 03:50 AM
smokecdxx
Mar 23, 2008 05:37 PM
memorybox
Sep 11, 2006 06:42 AM
