S300: VTEC Disengages in High RPM
I've tried searching and maybe I'm not searching the right terms, I don't know. My motor is a B18C5 and I'm using a P28 with a v3 S300. Here's the deal.....With the default VTEC window settings (Lower 5700 RPM 78.9 KPA, Upper 5700 RPM 40 KPA, and TPS 40%) I was having issues of VTEC disengaging at partial throttle and high revs (like 7000+ RPM). To remedy this I set the TPS to 0%. It works but now I have issues with getting into VTEC on the highway (lowered VTEC RPM and a 4.928 final drive). If I crank up the TPS percentage, then I'll be back to square one. I do NOT want VTEC disengaging at 7500 RPM when I ease out of the throttle to maintain a steady pace through a series of corners. I'll deal with the highway woes if I have to but can't I have my cake and eat it too?
Thanks,
Frankie
Thanks,
Frankie
Have you read the info in the s300 help file on how the VTEC window works?
VTEC Parameters
VTEC Parameters
VTEC Parameters
VTEC Parameters
William5353
May 8, 2016 05:47 AM
