Question about JUNII/ITR cam set ...
Old Nov 7, 2002 | 09:56 PM
BlackGSR's Avatar
Default Question about JUNII/ITR cam set ...
Hey,
We all know that the JUNII/ITR setup CAN make great power. Especially in the midrange (Mike K). What are your feelings about dropping a Toda "A" cam instead?
I'm seriously thinking about doing it.
Adam
Old Nov 7, 2002 | 10:11 PM
BlackGSR's Avatar
Default Re: Question about JUNII/ITR cam set ... (BlackGSR)
... on a 2.0 ltr 12:1 CR motor (Hondata).
Old Nov 7, 2002 | 10:18 PM
Mr Hammond's Avatar
a/k/a Jomo
**** I'd say TODA B's, Maybe C's, or JUN III's or SKUNK2's. Why go mild with the top end?
Old Nov 7, 2002 | 10:20 PM
BlackGSR's Avatar
Default Re: Question about JUNII/ITR cam set ... (Mr Milano)
I don't really want to upgrade the valvetrain because I bought a BRAND NEW ITR head. So, basically which cam would make the most horsepower. (Using ITR valvetrain).
Adam
Old Nov 7, 2002 | 10:21 PM
TypeR 599's Avatar
spoon
Old Nov 7, 2002 | 10:24 PM
Mr Hammond's Avatar
a/k/a Jomo
:sigh: i guess just go with the JUN II intake cam. unless you planned on getting both toda a's. or just stick with stock untill you have the money. i think it'd pay off more.
BlackGSR's Avatar
Default Re: Question about JUNII/ITR cam set ... (TypeR 599)
spoon
Spoon cams are not cheap. The MOST I'll spend is like $700. Figure Spoon's go for like 800+ I might as well just get JUN/Toda warriors.
ITR
CTR
JUNII/ITR
TodaA/ITR
Still debating Skunk2 stg 1 (quality issue).
Adam
Old Nov 7, 2002 | 10:26 PM
BlackGSR's Avatar
I'm through spending money on my car. I just want to be "finished" and enjoy.
I'll MOST definately be proud of a 200+ WHP car.
Adam
Old Nov 8, 2002 | 08:05 AM
Racebrewer's Avatar
I have the JUN II intake/ITR exhaust combo and it works just fine with the stock valve train. My intake is advanced approx. 5 degrees. My SMSP header gives great mid-range power and nicely matches the above set-up I also tuned the length of my home-made intake/cold air box to match.
The JUN II is bigger than a Toda A, but still has primary lobes closer to stock than a Toda B so there fewer idle issues (as I understand it-never tried B's).
Reasons not to go with bigger cams:
MUST upgrade valve train.
Loss of effective compression.
Greater wear and tear on belt.
Shifting power band up the rpm band requires a change in gearing/ECU fuel cut-off to get the most out of cams.
Need bigger injectors
What did I forget?
John
Old Nov 8, 2002 | 08:07 AM
Racebrewer's Avatar
Default Re: Question about JUNII/ITR cam set ... (Racebrewer)
Oh yeah!
Got my JUNII intake cam through Titan Motorsports. Wes and Bottle are Good Guys!
John
Propulsion
Oct 6, 2003 01:16 PM
Black R
Jul 16, 2003 03:48 PM
Dr Pooface
Feb 27, 2003 07:53 AM
StinkyTofu
Feb 7, 2002 09:07 PM
Gong Show
Aug 10, 2001 08:43 AM
