Transmission & Drivetrain Gearboxes, Differentials, Clutches
MFactory 1.5way clutch/plate LSD
Old Jul 25, 2016 | 01:30 PM
Junaid K's Avatar
Default MFactory 1.5way clutch/plate LSD
Hi. I have a 98 JDM DC2 ITR.
I recently fitted the above diff along wuth a Fidanza flywheel, and it's doing all sorts of weird things.
I've been told it can most likely be attributed to the incorrect oil being used. I'm currently using Castrol Axle Z.
I have been informed by the local South African MFactory agent that Synchrotech won't supply oil out of the US, which leaves me in a bit of a predicament.
As an alternative, can I use Red Line MT90 with no additional friction modifiers?
Old Aug 15, 2016 | 08:42 AM
Aquafina's Avatar
Default Re: MFactory 1.5way clutch/plate LSD
You can use the Redline fluid, but the diff will still be clunky and make noise without a friction modifier added in. Is Motul fluid available? Check with the Torco distributor (RG Motorsport to see if they can get some RTF and Type F Friction Modifier for you.
YATCHI
May 11, 2013 02:39 AM
BRN12345
Oct 11, 2009 03:52 AM
6Spd_EJ6
Dec 12, 2007 09:42 PM
Black R
24
Mar 10, 2007 05:23 AM
Knestis
Jan 23, 2005 09:16 PM
