what kind of supercharger
Old Nov 7, 2002 | 09:05 PM
justmotor13's Avatar
Default what kind of supercharger
i've got the b16 in adn i'm thinkin about supercharging my car but i've heard good adn bad things about the jackson racing model and the vortech model. Which one should i get? vortech is pretty much liek a turbo so is it worth it to get it, we'll the jackson racing has a more spread out power band. What do u think should i upgrade if i did supercharge?
Old Nov 7, 2002 | 09:32 PM
MADEINIRAQ's Avatar
Default Re: what kind of supercharger (crx31286)
vortech is a lot of money.. i'd rather turbo than the vortech since it has lag like a turbo.
jackson racing supercharger is the way to go i would say.
Old Nov 8, 2002 | 04:58 AM
D16Z6racing's Avatar
Default Re: what kind of supercharger (madeiniraq)
For supercharging, I'd get the JRSC.
Turbo is more in my mind though. If you're worried about lag, just don't get a huge turbo. Smaller ones spool up faster. My GReddy kit lag is almost un-noticable. The T3/T4 is pretty popular to reduce lag too.
Old Nov 8, 2002 | 07:21 AM
JoshDM's Avatar
jackson sucks assssssssssssssss!!!!!!!!!!!11
votech if you want to supercharge
Old Nov 8, 2002 | 07:28 AM
USDM 4G VTEC's Avatar
Default Re: what kind of supercharger (JoshDM)
i second that
my buddys GSR had a JRSC and that **** didnt really pulled... they send him a 5 psi kit and that thing never got pass 4 psi.... and then they wanted to charge him about 1100 for another pulley kit to boost it up...
Old Nov 8, 2002 | 07:39 AM
Wes V's Avatar
Default Re: what kind of supercharger (JDM EF9)
In researching it, I'm planning on going with the JRSC. The problem that I see with it however is that the fuel management set-up that is part of the kit isn't the correct way to do it. I believe that in order to get CARB certification, they are limited to using the stock ECU and have to "band-aid" around it.
The correct way to do it is to go with larger injectors and a programable ECU (Zdyne gold).
I got a chance to ride in a 4G civic with D16Z6 with this set-up. The power curve was smooth and strong. Impressive!
Wes.
skud_dusty's Avatar
say a guy runnin a gsr with jrsc. was pretty tuned, had the jdm itr header, most bolt ons and slicks...the fastest he ran was like a mid 14, and he was driving very well.
just from that jrsc
Old Nov 8, 2002 | 10:06 AM
keebler65's Avatar
Default Re: what kind of supercharger (skud_dusty)
i thought the compression of the gsr motor was less than the b16 though, which means the boost would be less effective. from everyone that i've talked to, they say supercharging a b16 with the jrsc is a wicked setup. thats what i'm planning on doing next spring. as far as the fuel setup, look around in the FI forum - it sounds like the new SMC unit made by zip is a really good way to manage the fuel. you end up using the stock fuel system with exception to larger injectors. just a suggestion since we've all heard bad things about jr's fmu.
Old Nov 8, 2002 | 12:19 PM
zCivic's Avatar
Default Re: what kind of supercharger (keebler65)
My response to JRSC is forced hot air induction. There is no sense in it. Find a kit that uses a innercooler same situation a with a turbo. A turbo with out a innercooler runs quite a bit slower then an innercooled one. The cooler may reduce boost by a couple psi but in the long run worth it.
Old Nov 8, 2002 | 01:12 PM
Blown90hatcH's Avatar
What a stupid response. And most of the others are just as bad. Most of the "JRSC is worthless" responses are heard, my buddies, read.....Do it yourself and then explain to me why my car and many others put down 250-300 everyday. Up the boost from the stock psi kit and see your results. Yes, it isnt very efficient after 10psi, but it is a wicked street setup. If you want 250-300 whp with instant boost, get the JR. If you want more power, get a turbo setup. I sold my JR for a turbo setup as I am in search of 10s.
Old Nov 8, 2002 | 02:39 PM
NaSh123's Avatar
from what i've heard i'd probably get the Jackson Racing supercharger
Old Nov 8, 2002 | 02:43 PM
Rob!'s Avatar
Default Re: what kind of supercharger (NaSh123)
i would get a small turbo kit
GsTurbo98
Nov 8, 2007 08:09 PM
Crx_Civic
Sep 2, 2007 11:31 AM
1997GS-R
Oct 13, 2005 08:24 AM
NA-C5
Nov 27, 2003 06:31 AM
RobertMcDonald
May 7, 2002 12:46 AM
