Bolt near oil pan leak
What is this bolt for? if ever it leaks again, will oil come gushing out if i unbolt it to reapply rtv?
Most important thing is that the bolt is properly torqued to spec.
From the banked wall, and inner joint location, this appears to be a V6. If so, that bolt is one of the cross bolts for the main caps. Make sure it is properly torqued and not just 'tite enuf'.
I just found this thread and have a question. I have a 2002 Accord with the same exact bolt leaking pretty badly. Seems easy enough, but saw another place and cannot figure if bolt is right or left threaded? Does anyone know torque once cleaned, rtv'd, and put back in? Thanks!
