My 62mm EG Civic
Old Jul 19, 2016 | 08:55 AM
DA 4 Lyfe's Avatar
Default My 62mm EG Civic
Hello all,
I would like to share my new project car with you guys. I am not new to the forum but some of you might remember my 92 Integra DA:
New chassis is a 92 EG Civic hatchback:
Setup:
The car still needs paint/body work but that will be happening in the winter of 2017
Engine:
B16A2 Head- RLZ steet/strip service
B18C1 Block- 84MM Benson Sleeved
Fully balanced & Micro Polished LS Crank (done by Applied Flow in Clifton Park)
CP 9:7:1 Pistons
Manley Turbo Tuff Rods
ACL/Clevite Race Bearings
Ported Victor X IM (done by Applied Flow in Clifton Park)
OMNI 70MM TB
Skunk2 Pro 1 Cams
Golden Eagle Cam Gears
Ferrea Comp. Plus Valves (stock size)
Supertech Springs & Retainers (85lbs)
ARP Headstuds
OEM 84mm Golden Eagle Head gasket
Brad penn 10w40 engine oil
Turbo Kit:
Synapse Motorsport T4 Twin Scroll Manifold
Precision BB 6266 Gen 2 wheel 1.00.ar
Quantum Race Works 3 Inch Intercooler Piping
Sheepey Built 1000whp Intercooler
Tial MVS 38mm Wastegate's with 11.6 pound springs
Tial Q BOV
3 inch Downpipe
4 inch staight pipe exhaust to the back bumper
Transmission:
Competition Twin Disc Type C
Quaife LSD Differential
94-01 GSR Transmission
Red Line Lightweight Shockproof Gear Oil
Fuel + Management:
Hondata S300 V3 tuned by Steve Andrew at Quantum Race Works
Tuned on Pump E85
ID 2000's
FCS Fuel Tank (8 Gallon)
Dual Bosch 044's
-8 Feed & -6 Return Fuel Lines
AEM Fuel Rail
AEM FPR
M&W Pro 10 Ignition and Crane PS92 coil
OMNI 7 Bar Map Sensor
Blox TPS Sensor
Wheels + Supsension:
Blox Drag Coilovers
DSS 2.9 Axles
Front Rota Slipstream's Mounted On Toyo R888 235-50-15's (For the Street)
(Weld drag wheels 13x10 mounted on 24.5 x 9.5x13 M&H slicks for the Track)
Weld REAR skinnies ( for the Track)
Rear Rota Slipstream's Mounted on Kumho Sense 195-65-15's
Hasport Mounts (70a)
Skunk2 Pro series Front Camber kit
Blox Rear Camber kit
Blox Spherical Rear LCA
Corner balance and scaled with Alignment
Exterior:
Exospeed Carbon fiber front end
Sebion OEM style Carbon fiber Hood
Sebion OEM style Carbon fiber Hatch
Interior:
Full Interior Seats carpet plastics all kept in tact
Autometer C2 Oil Gauge/ C2 Boost Gauge/ Big C2 Tach/ / AEM wideband / AEM Water Temp
10 Point Roll Cage and Chute mount done by NRG TECH
Corbeau A4 Seats with G-Force 5 point Harnesses
Old Jul 19, 2016 | 09:21 AM
unknown4now's Avatar
Default Re: My 62mm EG Civic
Setup looks Your DA was a beast. Good Luck with new project !
Old Jul 19, 2016 | 09:47 AM
2000GSRTypeR's Avatar
Congrats Brian!
Old Aug 8, 2016 | 07:01 AM
CDecker0218's Avatar
Update with the civic. My brother took it out to our local track for the first time. Went 10.36@143 on its first full pass ever. Boost level was 23-26. More to come this Wednesday!
Old Aug 8, 2016 | 11:47 AM
paulzy's Avatar
gonna be runnin 9's in no time.
Old Aug 8, 2016 | 12:41 PM
Dark_Teg's Avatar
Nice, I love Sheepey parts!!!!
Old Aug 8, 2016 | 01:11 PM
DA 4 Lyfe's Avatar
Some pictures from last track day:
Car went 10.3 at 143 on its first full pass. It was on 23-26psi. The car made 837 at 42psi. More to come on Wednesday!
Old Aug 10, 2016 | 02:47 AM
blackeg's Avatar
looking good 9's in no time! Hopefully ill run into you guys at the valley this year and check it out in person.
Old Aug 10, 2016 | 05:46 AM
extremeracer's Avatar
Knocking on the door.... What is your race weight ?
Old Aug 11, 2016 | 06:25 AM
DA 4 Lyfe's Avatar
Went back to the track last night 8/10/16 and ran a new personal best ET and MPH! Only 2 passes at the same boost level. (mid 30's) Going to turn it up next time out and work on the short track:
Old Aug 12, 2016 | 01:04 PM
Steeve_Civic's Avatar
Nice setup, you gonna hit 9s next Time for sure!
pictures of your engine?
how do you control your boost per gear?
Old Aug 13, 2016 | 02:12 AM
DA 4 Lyfe's Avatar
Thanks man, I will be turning the boost up nice time out for sure!
I use gear based duty cycle on S300 with a MAC 3 port solenoid
Old Aug 13, 2016 | 10:51 AM
Good luck
post some picts of your engine If you got some
Old Aug 22, 2016 | 08:28 AM
DA 4 Lyfe's Avatar
Originally Posted by Steeve_Civic
Good luck
Here are a few photos. The engine bay isn't anything special, its dirty but gets the job time lol
Old Aug 25, 2016 | 11:28 AM
Haven't gotten it weighed yet, but it has full interior with a NRG tech 10 point cage. Guessing around 2500lbs with my brother in the car.
Old Aug 25, 2016 | 11:23 PM
Thanx, my car is quite similar . Full interior, power windows, door locks and mirrors and a 8-point steel cage.
Old Oct 2, 2016 | 07:55 AM
DA 4 Lyfe's Avatar
Took the car to Lebanon Valley Drag way yesterday for some more testing and picked up a new personal best ET and MPH! 9.85 @ 152.72
10/1/2016
Old Oct 2, 2016 | 11:26 AM
GoldieWang's Avatar
10 Year Member
good to see you hit the 9's!
Old Oct 3, 2016 | 08:30 AM
DA 4 Lyfe's Avatar
Thank you. I should be out next weekend as weather depending!
Old Oct 3, 2016 | 12:59 PM
paulzy's Avatar
badass. such a simple setup but it scoots
DA 4 Lyfe
Apr 19, 2017 10:59 AM
DA 4 Lyfe
Nov 30, 2013 09:14 AM
boosted03
May 28, 2013 06:38 PM
OneSixxKyle
May 23, 2013 12:07 PM
DA 4 Lyfe
Sep 4, 2011 03:22 AM
