f23 02 ACCORD LX TURBO BUILD
Have you tried searching before you asked any of those questions? Just saying that would be a great place to start. I found it all on GOOGLE.
Yes those pistons fit.
You should ask more specific questions. You'll get more help that way homie.
would i have the same compression
depends on if you rebuild your block or not and where u get your parts from
rebuilding block pistons rods = 1500-2000
injectors = about $500
EMS = 500
tune = 500
fuel pump=$100
and thats not even including turbo parts I dont know of any kits off hand for f series usually kits start at $2k
EMS = 500
tune = 500
fuel pump=$100
You have a crap motor to build/boost as parts are scarce.
Cheap H beam rods - $250.
Wiseco K20 pistons - $500.
Bearings/seals/etc - $150-250 depending on what quality you go for and race or regular bearings.
Machine work - $200-300 for hone, micropolish crank, deck, etc. Assuming you gap the rings, spec the bearings yourself, and do the engine assembly. More if not.
Valvesprings - $250.
Timing belt/water pump kit - $100-200, again depends on quality.
Headstuds and headgasket. -$200+
Balance shaft delete kit(optional) - $150.
Flywheel resurfaced - $50
Clutch kit to handle 400hp - $350+.
Turbo - $700-1000+ depending on model and options chosen.
Manifold - $100, cheap log will get you to 400hp.
Custom downpipe fabrication. - $100-200
Intercooler/piping/etc - $400+
Wastegate - $230 for a precision 39mm.
BOV - $200 for a cheap greddy.
Fuel injectors, pump, etc - $250-400+
ECU, conversion harness, tune - $1000 easily.
I'm sure I'm forgetting some things.
So, if you're keeping score so far that's a total of about $5000 on the low side. It can and easily will shoot up even more in price as small labor costs, little parts here and there, etc add up. There are a lot of hidden costs doing this sort of thing that aren't always so obvious.
This also doesn't take into account the suspension and brakes on your car that will need to be upgraded to handle the extra power if you want the car to be even remotely safe. Also at 400hp it's a good idea to upgrade to a better radiator setup which will run a few more hundred bucks.
Oil lines, fittings, some sort of catch can setup add in another $300.
as aradin said his quote was definetly on the cheap side no way I could get a custom downpipe around here for $200. also when piecing together a kit yourself your bound to make mistakes/fitment issues especially if you have not done this before which increases the cost
theres money to be saved if you dont go for rebuilding the block and stay arround 300hp assuming your block is healthy
Yup. I also forgot aftermarket engine mounts which would be pretty much mandatory at that power level as well. That's another $250. Even then you'd be praying the sleeves didn't crack because of the long stroke this particular engine has.
I wouldn't even trust a stock F23 at 300whp honestly. Maybe around 260-280 tops. The rods on them are much smaller than the F22s they're derived from. They have headgasket issues moreso as well.
My best advice would be to call go autoworks and see if hes willing to build a kit, im sure he has done so in the past. that cuts down on parts not working with eachother and fitment issues
K swap will be out of your budget and not worth the gains. H23A blue top would be better than a standard H22 and just as cheap.
Seems like you want cheap power. Sell the Accord and buy a cheap LS1 Camaro/Firebird or something along those lines.
with your budget you may want to change your goal. If you're just looking for a fun car just boost the f23 and call it a day. as stated before you'll be limited on the setup but it gives you a fun car to drive. Another option would be is just to sell the car and buy a civic. but not sure if you want to go that route. theres more option in that direction. Good luck either way.
smoker2400
Jul 20, 2005 01:31 PM
