Turn signal help?
Old Jul 12, 2016 | 05:14 PM
97civic_V-Turd's Avatar
Default Turn signal help?
Okay so here's the deal. My left turn signal will work when it wants to. If it stops working I will tap the headlight and it'll work again. I checked the fuses as well as the bulb. The filaments in the bulb look good. I was thinking the bulb socket could be bad. A friend suggested it was a short in the wire so I check and the wire has a plastic protective cover on it. Anyone have an idea what it could be? Thanks in advance.
Old Jul 13, 2016 | 05:10 AM
Former User's Avatar
Default Re: Turn signal help?
Have you tried replacing the bulb?
Old Jul 13, 2016 | 05:50 AM
mk378's Avatar
You mean when you tap where the bulb is, it starts working? Like Ron said, the first thing to try there is a new bulb. I have had bulbs with loose connections inside, they look OK but don't always light up.
W95civicEXcoupe
Mar 5, 2015 02:51 PM
pcorad
Jun 8, 2008 02:18 PM
rkrone
14
Aug 26, 2006 06:38 AM
RiCeRTeG
Jan 27, 2005 10:58 PM
