Can a radio be mounted where the climate controls are? Civic 95 EG HB
Can a radio be cage mounted where the OEM climate controls go?
I'm unsure if the radio can be mounted without removing the dash completely and bracing it from the back.
This would be done on a non-modified Civic 95 EG HB.
Edit:
The answer is no. The climate controller is larger than a radio, and thus will not accommodate a radio cage without some modification.
Thank you!
This thread can be deleted.
Thank you!
dL_EG6
Sep 10, 2007 08:00 AM
