CRV speedo issues
Greetings fellow Hondaphiles.
My trusty 1996 CRV (automatic, 4wd) threw a hissy fit of sorts this morning.
Started and warmed up as per usual. Drove away and noticed speedo not working....until brakes applied , then speedo works until braking ceases and then speedo stops working again
. 2 or 3 minutes into journey the Check Engine Light comes on also and stays on till engine turned off. CEL comes on and goes off after a few seconds when ignition key turned on to start vehicle (as it should)....then comes on and stays on after a few minutes. Coincidentally had a blown left brake light bulb (now replaced) Am thinking maybe vehicle speed sensor ?? but why would the speedo start working again under braking ? Wierd
Will get it to a diagnostic tool for check up....but any ideas out there?
Thanks in advance.
Will get it to a diagnostic tool for check up....but any ideas out there?Thanks in advance.
Arsalanrasool
Mar 6, 2016 07:38 AM
Bad_dude
Jun 5, 2008 01:09 PM
Chicano
May 8, 2005 08:43 PM
importdreamer
21
Jan 6, 2005 06:10 PM
