any boosted cd5 accords out there?
Old Jul 4, 2016 | 08:17 AM
h1ghboost's Avatar
Default any boosted cd5 accords out there?
hey guys, i am in the process of boosting my 94 accord coupe (f22b1) and was wondering about other boosted cd5 accords, what setups worked for you guys and what didnt. any suggested IM's and different heads, how long yor internals lasted and how you tuned the car etc. THE WHOLE 9!!
Old Jul 7, 2016 | 09:03 AM
h1ghboost's Avatar
Default Re: any boosted cd5 accords out there?
bump, anyone??
Old Jul 7, 2016 | 05:17 PM
LeeMajors19082's Avatar
10 Year Member
I'm having a minor issue with mine atm but check out the build log in my sig. Also use the search function there's quite a few F-series turbo builds on here but it's not very easy to find a lot of the OP's of those builds around the forums these days. Lastly, check out HondaSociety.com their 5th Gen Accord community is MUCH more lively than this one and there's good amount of SOHC turbo builds there too. GL
Old Jul 7, 2016 | 05:21 PM
Aradin's Avatar
Premium Member
Do an F23 intake manifold swap. Buy a larger throttle body to go with it and bore/port match the upper plenum. You'll get good gains for little cost NA or boosted.
I've had many turbo setups in my CD5 over the years. The middle limit of the stock internals is about 300wtq. Dial that back some if you want longevity. Go a little further if you want to risk spitting a rod out. Pistons won't be an issue with a good tune.
Headstuds are cheap insurance for headgasket issues above 12psi.
Old Jul 7, 2016 | 06:07 PM
h1ghboost's Avatar
thank you i appreciste it. i actually read your whole progress log on your build today at work. very informative and it inspired me to pull the motor from a parts car i bought. same motor f22b. i plan on following your footsteps in the build process as insurance in a sense (if my motor blows). im between boosting my stock motor or not. i have a healthy motor 150k miles. i plan on replacing timing belt and other gaskets to support. need to tweak out what clutch to get and then dump 500-600 on a tune. just little hiccups.
anyway, please keep posting in your log, i am all eyes! keep up the good work and thanks for the reply
Old Jul 7, 2016 | 06:09 PM
h1ghboost's Avatar
on your past setups have you tuned yourself? im between paying for a professional tune and buying an ostrich enulator myself and tuning with crome. any suggestions?
btw my setup is only estimated 250whp.
running 4g63 custom mani.
450cc inj (dsm)
evo3 big 16g turbo
255 fuel pump
p28 ecu
evo 8 fmic
etc.
Old Jul 7, 2016 | 06:25 PM
Aradin's Avatar
Premium Member
Yes I tune all my setups myself. I've been tuning for many years now. Don't waste your money on Crome. Save a little more and get Neptune RTP. You'll be glad you did.
Old Jul 7, 2016 | 06:31 PM
h1ghboost's Avatar
im not very firmiliar with tuning, any insight? any i was going to go with crome free. but now i will follow your advice, do you use an emulator to bridge between pc and ecu? i assume yes, which do you use?
if there are any informative links you can throw my way for tuning let me know id appreciate it
Old Jul 7, 2016 | 07:55 PM
Aradin's Avatar
Premium Member
You'll need to start by doing a lot of research and reading on it. If you're not willing to do that then just take it to a professional.
Neptune RTP doesn't require an emulator. It uses a separate add-on board, called a demon, that allows users to directly interface with the ECU and software.
Old Jul 10, 2016 | 12:46 PM
93cavRS's Avatar
I have a boosted CD. 17psi on the stock motor via a Garrett 57 trim tuned on NepTune RTP
Old Jul 10, 2016 | 02:17 PM
10 Year Member
I'm just curious, what kind of power are you seeing on 17psi?
Old Jul 10, 2016 | 04:01 PM
h1ghboost's Avatar
please tell me more info about your motor specs and your setup!!
hawk4209
Jan 10, 2020 09:22 AM
busha61067
Feb 14, 2010 07:32 PM
jonnyad
Jun 1, 2007 11:47 AM
jdefranc938
Oct 20, 2004 07:00 AM
Dreaded Sin
May 26, 2004 05:35 PM
