Cooling system issue
Hey i have a 91 honda accord I changed the thermostat an the radiator cap. it still has pressure on the holes. An started to run hot. when I trun off. it cool off but it makes a click noise. Whts that QUOTE=-Gary-;26923509]Sounds like you have a leaking headgasket.
What PSi is your radiator cap rated at? That should be the thiong that releases the energy before your hose gives way.
Do you have radiator fluid or just water?[/QUOTE]
robbys89
May 13, 2009 12:02 PM
mingbling96
Jul 1, 2005 05:50 PM
