All motor J series
Old Jun 29, 2016 | 08:38 AM
hondaracing84's Avatar
Default All motor J series
So I just wanted to share real quick my all motor j series setup. I don't know if anyone remembers me on here before, but here is a little back ground. Years ago I was racing in the IFO fwd class with my 800hp civic. Ran a PB of 10.02@150mph. Then after throwing a few rods I switched to all motor to give it a try. I figured Id do that for a season or two while I built a very strong turbo engine. Well, I kinda got hooked on all motor and was having a lot of fun. I run in the AMS class. I did B series for 2 seasons. Made about 270hp and ran an 11.7@117mph.
After I found my head was damaged during winter maintenance/upgrades, I decided to bite the bullet and go J series. I had been thinking about it for a year. Instead of getting a new head, porting it and doing my planned stroker, I figured I could just spend that money on a J swap. Best decision I ever made. This engine is a junk yard engine. Bone stock except bolt-ons. It made way more power and torque stock than the fully built race B series. And it ran the same times. Oh, and all on pump gas. The B series was on methanol.
So here is the setup.
'01 Acura CL Type-s long block
Skunk2 B series Throttle body
port matched intake manifold
DC sports headers
3" K-teller exhaust
Clutch masters aluminum flywheel and clutch
type-s 6 speed transmission
DSS 2.9 axles
K tuned billet RSX shifter
rsx shift cables
Wireworx J swap harness
Tuned on AEM V2
91 pump gas
Made 312hp dynojet. Cant remember the torque, still haven't gotten the dyno sheet.
So to date with this setup I ran a PB of 11.7@114mph
Im making a few small changes that will hopefully help and get my mph up and times down.
UPDATE: 11/22/16 on last page.
Old Jun 29, 2016 | 10:01 AM
flatblack-h22's Avatar
Default Re: All motor J series
NICE! got one also, just needs to be tuned. 90mm tb and custom long tubes.
Old Jun 29, 2016 | 11:18 AM
That's what I need, long/big tube headers.
Im building this slowly. Starting from the bottom and working my way up. Putting a 3.7L crank in, inline pro rods and some pistons to raise the compression. Then Ill do the heads. I think the 90mm tb and custom intake will be the last thing.
Id love to see those custom long tubes you have. How much did you pay for them?
Old Jun 30, 2016 | 04:05 AM
Pro-SeriesFab's Avatar
Nice!
How many miles were on the motor?
Old Jun 30, 2016 | 05:49 AM
I cant remember, I think 125-150,000.
Old Jun 30, 2016 | 07:49 AM
i got them second hand but still new, so they were cheaper. original owner had rameybuilt make them with all burns collector and vibrant piping. second guy got them swaintech coated.
precoated
Old Jun 30, 2016 | 07:54 AM
Yeah, Ive actually seen those. Really nice. I really wish I could get a set. I think Im just going to get a friend, who is a fabricator, to make me a set. I don't want to go too crazy since I plan on going hood exit in a few years for the all motor pro class. So I just want the same design I have now, but a little longer tubes and bigger. Just need the exhaust to flow a lot better.
Old Jun 30, 2016 | 11:47 AM
SwappedTURBOegg's Avatar
glad to see more J cars. i have a cheap intake solution good for picking up 15% up top on stock cams.
Old Jun 30, 2016 | 12:01 PM
paulzy's Avatar
nice. I have a J too but turns out I had some bent valves that the junkyard didn't disclose to me so I decided to just rebuild the heads with some portwork, so that held me back.
I have made plates for intake manifold plenums though if you're interested in the future. Made one for my set up and had a few extra made at the same time.
Old Jun 30, 2016 | 12:05 PM
^man that looks nice. overkill for stock runners. cant wait for the cnc runners to be finished by asp headers.
Old Jun 30, 2016 | 12:15 PM
paulzy's Avatar
was thinking about having my CNC guy make some runners but my budget only agreed with ported stock runners for now. lol
Old Jun 30, 2016 | 01:40 PM
PM me. Im considering all options.
Old Jun 30, 2016 | 01:41 PM
PM'd you. Im considering all options.
Old Jun 30, 2016 | 02:54 PM
cruizinmax's Avatar
Is that a Holley high ram Intake manifold? If so have you considered the 417Motorsports intercooler?
Old Jun 30, 2016 | 06:23 PM
that ****** is 1400 bucks so no lol
Old Jul 1, 2016 | 12:28 PM
jdm inc's Avatar
looking good shane!
Old Jul 1, 2016 | 01:47 PM
Dang man, you didn't want to flip the inlet to the intercooler to face the front and get rid of a 180* bend?
Old Jul 2, 2016 | 08:16 AM
ATYPR's Avatar
Do tell
Old Jul 2, 2016 | 08:08 PM
there isnt enough room.
Old Jul 5, 2016 | 05:35 AM
Originally Posted by jdm inc
looking good shane!
Thanks man!
Old Jul 11, 2016 | 01:54 PM
TRUSE-R's Avatar
Nice build..
Old Jul 16, 2016 | 07:30 AM
Originally Posted by TRUSE-R
Nice build..
Thank you!
Old Jul 17, 2016 | 02:58 PM
PSI GUY's Avatar
What was the weight difference in the car with the swap and what are you at for weight now?
Old Jul 17, 2016 | 08:26 PM
redGSRguy's Avatar
Nice build. TB from SD has gotten some good results out of the J when it can put the power down. Did a 9.82@143.37 against us at the first event of the year.
Old Jul 17, 2016 | 09:39 PM
Black R's Avatar
25 Year Member
This.
Front to rear weight must be a con compared to K?
