How To Test My ECU?
Old Jun 28, 2016 | 01:23 PM
Dunc's Avatar
BCICAN
Default How To Test My ECU?
Background:
- Car is a 1997 Integra LS/VTEC with Hondata S300 using an OBD1 conversion harness and a P72 ECU.
- Ran flawless for years. Sat untouched for several years. I'm ready to sell and move on to other stuff.
- Had some horrible (i.e. undriveable) bucking/stalling issues. Fixed it from what I thought was faulty injector harness wiring. This was after replacing damn near everything. Ignition system, fuel system, injectors flow tested, TPS, MAP, everything. The driveablity was good after I corrected faulty injector wiring, but that was short lived.
- Now the car starts but dies as soon as you touch the throttle just like it did awhile back.
- Gave up and gave the car to the tuner to see if he could figure it out. He is leaning toward the ECU being bad which makes sense to me and would explain everything.
Question:
How do I test the ECU? Is that something you just replace? I haven't looked at the ECU in a long time,...can the S300 be swapped over to a virgin P72 ECU? By swapped I mean just unplugged the S300 and put it on the virgin ECU's circuit board. Or is that something you have to send to Hondata and they install on the circuit board?
My only reservation about trying this is the cost really. I am not interested in spending $500 for a new S300 from Hondata on top of whatever an ECU would cost which I'm guessing is another couple of hundred. I just don't like taking $6-700 shots in the dark for something that will hopefully fix it.
Any suggestions on how I can obtain a known good P72 S300 ECU to see if it makes the car run right again? My truck is really wants the Integra to work and get sold so it can get a set of turbos.
Tkthedk
May 10, 2012 08:45 AM
nycpatron
Mar 1, 2010 02:14 PM
lsjon
Engine Management and Tuning
May 30, 2008 08:41 AM
CRX_Control
Nov 21, 2004 01:27 PM
TheMasterG
Aug 2, 2002 07:27 AM
