LSD in B16a tranny?
actually both of the trannies listed above are cable trannies.
i personally used to have a Kaaz LSD installed in a JDM S1 until it died on me. since then i just switched the Kaaz unit into my 93 GSR trans and it fit fine. i just pulled the LSD from my JDM tranny (including the Ring Gear) and it just dropped right in. and bearing clearance was in spec to boot.
so basically, get an LSD made for a B-series cable tranny and use IT.
hth, J
hth, J
are you asking about using an ITR LSD??
well my Kaaz LSD dropped into my 93 GSR trans, so the ITR LSD should drop in also. BUT from what i have read you have to use the ITR ring gear with the LSD because the bolt pattern is different than other b-series trannies. and i believe using the ITR ring gear is a problem for JDM cable trannies that were 89-91 (ie. S1/Y1/J1). wish i knew more about it.
IMO you should stick with an LSD made for a cable trans.
i have a y1 LSD tranny for sale, the shift fork needs work but the lsd is in perfect condition and could be swapped over if you don't feel like working on the tranny. asking only 500$ for the whole tranny! let me know if you're interested.
infamousALLMTR
Mar 31, 2002 08:01 PM
at more power racing
