How can you tell if it's a B16a tranny?
Old Nov 7, 2002 | 06:17 PM
charjacq's Avatar
New User
Default How can you tell if it's a B16a tranny?
I will need a B16a tranny soon. How can I make sure it is a B16a tranny? Is there a specific code on the casing?
Thanks
Old Nov 7, 2002 | 06:23 PM
Fishcat37's Avatar
Default Re: How can you tell if it's a B16a tranny? (charjacq)
im going to assume that you mean that you mean the JDM first gen B16A motor. The JDM B16A cable trans are: Y1,S1,J1,YS1. There is a sticker on the trans case that says this.
Old Nov 7, 2002 | 06:26 PM
Redline130's Avatar
I think the only for sure way to tell that you got a B16 tranny is to actually bolt it up and drive with it. Then you can see your rpms vs. mph and determine if you got a usdm or jdm tranny. The jdm transmissions of course would have tighter gear ratios, so cruising at 70 mph in 5th gear your rpm should be like 4500 or so. This is just my experience driving with J1 and S1 trannies.
Old Nov 7, 2002 | 06:35 PM
charjacq's Avatar
New User
Default Re: How can you tell if it's a B16a tranny? (Fishcat37)
What's the difference between all those?
Old Nov 7, 2002 | 07:22 PM
AbaZ's Avatar
Gearing
J1/S1/Ys1/Y1 JDM/USDM cable style trannys have differnt gearing ratios as well, they will all mate to any B-series block
and the JDM YS1 has the optional LSD
Jeff
Old Nov 7, 2002 | 07:25 PM
88EF's Avatar
Default Re: How can you tell if it's a B16a tranny? (AbaZ)
Gearing
Jeff
So does the JDM Y1.
Old Nov 7, 2002 | 09:11 PM
Ham'ed Hatch
Guest
Posts: n/a
hey i've got a question...
are the gear ratios in the b16 delsol tranny the same as any of the y1, s1, j1, ys1s?
i know it's hydro not cable, just wondering gear ratios...
Old Nov 7, 2002 | 09:17 PM
MADEINIRAQ's Avatar
Default Re: How can you tell if it's a B16a tranny? (Ham'ed Hatch)
thanks to me for posting..
thanks to ff-squad for creating.. or whatever
http://ff-squad.com/Bgears.htm
Old Nov 8, 2002 | 05:12 AM
charjacq's Avatar
New User
Default Re: How can you tell if it's a B16a tranny? (madeiniraq)
Thanks!!!
guizaredwin4321
Feb 11, 2010 09:55 AM
integrawow
Mar 5, 2008 02:21 PM
sciolist
Aug 15, 2003 07:39 AM
