AIR CONDITIONING PEOPLE! Need help with adding AC into an EK with a B series swap!
Hey everyone!
I have a 1998 Civic DX hatchback that I swapped a 98 spec JDM B18C-R into. Unfortunately, I went all gung-ho when swapping it a few years ago, and I took the AC out. The only portion of the AC that's left in the car is what's under the dash, where it runs through the firewall.
After a few hot summers, it's starting to get old, so I'd like to put AC back in the car. The problem is that I got rid of all of the AC components when I took them out.
I'm not very familiar at all when it comes to AC, so I'm looking for some help, especially now that there's a B series swap in the car.
I'm looking and hoping that somebody could make me a list of everything that I would need in order to put air conditioning back in my car. I'm sorry for my extreme lack of knowledge on this subject.
Thank you in advance!
- DJ
- DJ
Ac compressor with brackets, compressor belt with tensioner, compressor crank pulley, condensor with fan, receiver/dryer, all the hard lines, and the wiring harness. I think that's everything.
Everything here... A/C HOSES - PIPES (1) for 1998 Acura INTEGRA HATCHBACK except evaporator and housing
And here... A/C COMPRESSOR (DENSO) (1) for 1998 Acura INTEGRA HATCHBACK
And here... 1998 Acura hatchback/gs-r-trim/5-speed-manual-engine/body-air-conditioning-cat/a-c-unit-2-scat except A/C evaporator and housing.
The only issue I see is connections to the evaporator, are they the same on a 98 Civic and the 98 GS-R that all the piping would be from????
Never mind, I checked, both are the same.
Some new parts here... https://shop.performanceradiator.com...4409_4436_4437
Things like lines, MT brackets electrical, and others you will have to get from the dealer or a bone yard, PicknPull] 94
