ID2000CC Injector Dynamics
I have for sale my lightly used ID2000s. B/D series also fits other applications. Had them cleaned and tested then put a couple passes on them.
$600 shipped to lower 48
Basic Specifications
Nominal Flow Rate – 2225cc/min @ 3.0 Bar (43.5 psi) Using Gasoline at 52 Degrees C (125 Degrees F)
Maximum Differential Fuel Pressure – 9.0 Bar (130.5 psi)
Fuel Compatibility – Compatible with Methanol/Ethanol/All Known Hydrocarbon Fuels. Incompatible with MTBE/Nitro Methane/Nitro Propane.
Electrical Connector – Denso
