JDM D15b dual carb idle misfire
Old Jun 25, 2016 | 11:19 PM
JDM rexy's Avatar
Default JDM D15b dual carb idle misfire
Hi i'm having problems with my 1991 jdm 1.5x crx (dual carb) it won't idle for more than a minute and idles rough.Its idling on two cylinders but running on four and feels like it has plenty of power. I did a compression test and all cylinders were above 160. I just replaced the distributor which made it idle for a minute and then stopped.I have checked for vacuum leaks and couldn't find any the two cylinders that are misfiring are on the same carb. what could cause the misfire?
Old Jun 26, 2016 | 08:43 AM
fcm's Avatar
fcm
Old Fart
Default Re: JDM D15b dual carb idle misfire
Defiantly sounds like a problem with the carb, can you swap the carbs and see if problem fallows the "bad" carb.
If it does, then it's time for a carb rebuild kit. 94
Old Jun 27, 2016 | 10:48 AM
kp's Avatar
kp
I wouldn't necessarily jump at a rebuild right away. Carbs are finicky and need to be very very clean to function correctly. My advice would be to remove the problematic carb and thoroughly clean it, pay special attention to the small orifices and channels within the body, use a good cleaner and blow out the holes with compressed air. Don't scratch or sand anything along the way, be gentle and use a soft brush or sponge to clean. Reassemble and see if that has improved the symptoms.
If it's already clean then I would find the factory instructions for setting idle speed, mixture, etc. and reset everything back to factory spec.
A side note, it would be wise to find a vacuum hose diagram and ensure that your hoses are all going where they should be. Your hoses may all be hooked up but they may not be in the correct place.
Old Jun 27, 2016 | 06:34 PM
~sp33~'s Avatar
EFB055
If you need a workshop manual for the carbs, feel free to PM me your email address and i can forward it to you.
Are you in Australia by chance?
Old Jul 17, 2016 | 09:26 PM
JDM rexy's Avatar
HI i'm still having trouble with idling i cleaned the carbs checked all the timing and the car runs mint for a minute or two but then runs on 2 cylinders and try's to die.it has good spark.The owner before me hacked up some of the wiring harness but have reconnected the sensors.He also removed the AC could this affect idle? The catalytic converter light is on in the dash could this make it run on 2 cylinders and can a bad oxygen sensor cause this?
Her94Hatch
Jun 3, 2015 07:30 PM
thewrai6th
Apr 29, 2014 12:59 PM
goldgreen90ef
Jul 9, 2009 07:13 PM
diLUDEd
Aug 22, 2002 10:08 PM
