Cam Gears
do not install crank pulley they will damage the motor (in particular bearings), sohc in particular use a harmonic balancer built into pulley which absorbs much of vibrations, with the aftermarket piece its absorbed by the crank.
as far as cam gear its only useful if you tune it on a dyno
