D16 turbo fitment
I have a question about my figment here. I have a d16y8 and am running an ac compatible manifold. Everything lines up and fits but the thing is that the very end of the slave cylinder where the nipple is is resting right Inside the compressor housing lip. Its not like close to the compressor wheel or anything. But its still sitting inside a little. Will this hurt anything? I know this side doesn't move when the clutch is engaged so I didn't think it would but wanted to be sure . thanks
Well, for starters you should probably put a filter on the turbo unless you don't care. Given the fact that you have an AC compatible manifold you're probably not trying to make some crazy power so if you don't care for a filter then just leave it.
You can also consider turning the turbo the other way so the compressor is facing the drivers side.
Rod.
Mar 23, 2004 04:22 PM
CheezeFrog
Jul 17, 2003 09:19 AM
