B series swap into an ek coupe
Old Jun 19, 2016 | 08:06 PM
Zack Tieleman's Avatar
Default B series swap into an ek coupe
Hey guys, hoping not to get roasted, just need an answer to my question. So I have a 1999 Honda civic coupe si and this weekend I swapped in an ls non vtec b18b1, got everything finished expect for the wire harness... Do I need to use a D series wire harness with an obd2b-obd2a jumper harness? Because I have the b18b1 wire harness on, and nothing connects to the p75 ecu (the car is obd2b and the engine and ecu I swapped into the car is obd2a) and I have a few wires that don't connect to anything? Please help, this is my first ever swap and I just need some help to get her running! Thanks in advance!
Old Jun 19, 2016 | 08:34 PM
tony_2018's Avatar
Fish Twig
Default Re: B series swap into an ek coupe
No. YOu didnt' specify what obd ecu.
Old Jun 19, 2016 | 08:39 PM
I fixed the thread, but the car is obd2b and the b18b1 and p75 ecu is obd2a, so I'm wondering, do I use my old D series wire harness, and then buy an obd2b-obd2a jumper harness so the D series wire harness (obd2b) can connect to the p75 ecu (obd2a)???
Old Jun 19, 2016 | 09:39 PM
tony_2018's Avatar
Fish Twig
Whats wrong with using the current engine harness in the car? Is this an em1?
Old Jun 20, 2016 | 12:21 AM
Spiff671's Avatar
If your car is a true 99-2000 Si (EM1), then your stock harness can be used. But yes, you will need a jumper harness to use the OBD2a ecu. eBay has some for around $85.
The distributor is another issue:
OBD2a: 9-pins
OBD2b: 7-pins (no tach signal)
Easiest dizzy fix is to use a B series non-vtec OBD2a distributor.
Or, install (solder) an OBD2a connector onto your main harness and run 2 additional wires from the dizzy into the car.
See this pic for info on the pinout differences:
http://ff-squad.com/tech/wiring/obd1-2dizzywiring.jpg
Old Jun 20, 2016 | 03:58 AM
OBD2a: 9-pins
It's not a true EM1, it's a Canadian Si, so it came stock with a D series engine. That's why I'm confused, because I can't use the b18b1 wire harness, **** doesn't line up, but the D series harness will line up with most things I believe, I would just need the jumper harness and do what you said for the dizzy
Old Jun 20, 2016 | 05:15 AM
Elpecoso's Avatar
I did this swap & used the stock harness. It all worked perfect
Old Jun 20, 2016 | 06:49 AM
tony_2018's Avatar
Fish Twig
Than you already have a d-series harness, all you need is to distributor adapter and the obd2b-obd2a harness. If you had the SiR harness everything would line up.
edit: you'll also have to repin the crank harness.
Old May 21, 2024 | 06:44 PM
Wylder's Avatar
swapped a b20 into my 99ek hatch used the D series harness just had to attend and change a few plugs
frankiecutz
Oct 31, 2015 03:49 AM
Tommy123
Classic Hondas
Oct 28, 2009 03:38 PM
Mikey3000
Jun 24, 2008 04:59 PM
PrecisionH23a
Aug 22, 2005 07:25 PM
