Jdm b18c idle problem help plz
Is the check engine light on? You might possibly have codes for the water temp sensor (ECT code 6) or the Intake Air Control Valve (IACV code 14)
Hi ,
Yes the engine light on . I did block a hole for Iacv in throttle body. And after blocking with finger the rpm becomes normal to 800 .as soon as I unblock the hole rpm goes back to 1500.
Thanks for your input . I have tried blocking the air intake that makes the emgine to die. But when I block both the holes in throttle body (iacv & ficv)
Rpm goes to 8000
Rpm goes to 8000
Did you adjust the idle air bypass set screw?
Adjusting your idle speed (Gen3) - Team Integra Forums - Team Integra
jmacsss
Dec 17, 2011 08:36 AM
psmoss
13
Jul 4, 2008 03:06 PM
