HELP!! Ignition Table D16 FJ Vitara Build 8PSI--IS IT SAFE??
Old Jun 17, 2016 | 05:02 AM
tyler8469's Avatar
Default HELP!! Ignition Table D16 FJ Vitara Build 8PSI--IS IT SAFE??
This is the tune that came with my car, I did not build it. I have been running the car and although it seems to run great I just want someones input on this ignition table.
I have an appointment with the tuner so I can be sure things are proper but it isnt for 2 weeks. AFRs all look good, bit rich at 5-7psi (11.0) but i will leave it until tune.
Car will only see 7-8psi before tune. Keep in mind this car was already tuned, however I have no information about the tuner or where it was done etc. To my knowledge this was a street tune and has never actually been on a dyno. So im just trying to be safe until i can get it redone and know what I have. FJ Vitara build D16, KMS block guard arp head and rod bolts, stock cyl head with exception to ferra stainless valves.
here is low cam and high cam tables.
thanks for any help you can give me!!
Old Jun 18, 2016 | 05:17 AM
tyler8469's Avatar
Default Re: HELP!! Ignition Table D16 FJ Vitara Build 8PSI--IS IT SAFE??
Nobody has any input here? Someone must have some insight on this map,surely d16 fj vitara builds or builds of the like are common on this forum.
Help appreciated if aomeone can shed some light on this!
Old Jun 18, 2016 | 11:14 AM
TheShodan's Avatar
Moderator
Ask a moderator to put this in the engine management forum.. That's why you're not getting responses
frejohg
Engine Management and Tuning
Nov 2, 2014 07:10 PM
flatblack-h22
Mar 18, 2009 11:55 AM
thehatchninja
Sep 3, 2006 01:48 PM
CivicTypeR00
18
Jan 18, 2004 10:27 AM
sneakychaos
Dec 23, 2002 12:04 PM
