Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Honda Accord EXL 2008 - AC Issue
Old Jun 14, 2016 | 07:05 PM
amitzbhushan13's Avatar
Default Honda Accord EXL 2008 - AC Issue
Hi Readers, I have Honda Accord EXL 2008 model which suddenly stops cooling the air when the AC is switched on. It started throwing hot air instead. But sometimes, it passes mild air as well. I have checked with Honda technicians and they told this might be "AC clutch is not engaging".
Is there a way I can confirm this issue or fix it, if found confirmed?
Thanks
Old Jun 16, 2016 | 03:33 PM
poorman212's Avatar
Default Re: Honda Accord EXL 2008 - AC Issue
When it stops "cooling" is the "face" of the ac compressor spinning with the belt or is is just sitting there....remember it does "cycle" on and off so you will need to watch it for a few minutes.
Is the HVAC unit giving any codes - different than pcm codes?
RGV
Jul 24, 2018 01:36 AM
Cmichie
Aug 2, 2017 06:39 AM
toughdame59
May 25, 2017 02:32 PM
MCBRUJA
Jun 17, 2016 05:07 AM
Jimmy1582
Apr 2, 2015 05:14 AM
