Custom Sheet metal guage cluster question
Hey guys, I removed my blower controls in my EG, and I am attempting to create a sheet metal guage cluster to replace the blower controls. But I am trying to figure out how I can create a way to support the cluster face so it doesn't fall off with the gauges. I have a ton of tools at my disposal. I was wondering if anyone has done this before and had some old photos or some suggestions on doing it. Thanks in advance.
Start over and leave enough material for mounting tabs OR make some brackets that can be attached with epoxy to the back side unless you like rivets showing (or screws).
how would i lay out the mounting tabs? It seems there is not enough space to put the gauges with all its retainers, along with mounting tabs, I was thinking about making a square housing, and using silicone to keep it in place. FYI I am planing on sanding out the rust, and painting + clearcoating over new and finished piece. Aluminium is hard to come by down here and I am using what I have available.
I believe the epoxy would also be a good idea, But i am having issues trying to envision how to make the brackets.
Is buying something specifically made for what you're trying to do out of the question?
52mm Universal Triple Gauge Single DIN Radio Face Pod | eBay
The screws are reached by pulling out the head unit and also the lower ashtray panel and using a long screw driver from the ashtray panel area.
Need to attach the panel to a cage just as big and that's also why I suggested the stereo single din cage to attach the face plate too.
Why don't you epoxy your face plate to a single DIN stereo bracket? It's already designed to slide in and stay in place with bend tabs.
Attachment 422882
Attachment 422882
Sanded the inside of sheet metal, and tacked a couple spots to the cage. (yes, I know, not the best welding in the world.) but I did the best with what I have.
