Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Rattle noise from Strut/Rear Deck (Civic EX 2015)
Old Jun 14, 2016 | 07:50 AM
FG2023's Avatar
Default Rattle noise from Strut/Rear Deck (Civic EX 2015)
I am being legally asked to remove all content from this thread and restrained from any comments.
I asked the WebMaster to delete this thread on 2016-09-22 20:35:00 EST and again on 2016-09-23 14:15:00 EST, it should be done shortly.
Thank you.
Old Jun 16, 2016 | 03:42 AM
holmesnmanny's Avatar
Default Re: Rattle noise from Strut/Rear Deck (Civic EX 2015)
Can you go over exactly what parts were replaced. I'm pretty sure you have shocks in the back not struts.
I will tell you after replacing my front struts(for no reason they weren't bad the noise was coming from the stabilizer link) I didn't quite have the spring seated fully in the upper spring insulator. I had a weird rattle that sounds oddly similar to that however I pulled the strut reseated the spring but I mounted the strut a lil bit differently in terms of tightening down the mounting nuts so I can't say if it was the spring not being fully seated or the way I tightened the mounting nuts but I'm confident it was more of the spring being about an inch from being fully seated causing my rattle.
However, if it were me I would start with the rear shock, it sounds like it's a rattle associated with that, I would pull it and make sure the spacer is facing the right way. It could even be the rear spring insulator not being seated like I had in my front. Perhaps the rear sway bar is loose or the rear sway bar bushing or the link is bad. The link should be tight with no play.
Edit: It looks like you don't have the rear shock spacer I have. Maybe the shock nut itself isn't tight enough. Check the rear lower spring insulator too, see if it's seated fully.
Old Jun 16, 2016 | 03:51 AM
I hate to ask but did anything fall into the spare tire area ?
Old Jun 16, 2016 | 05:17 AM
FG2023's Avatar
Thank you.
Old Jun 17, 2016 | 02:28 AM
Old Jun 17, 2016 | 04:06 AM
FG2023's Avatar
Thank you.
Old Jul 25, 2016 | 11:21 AM
FG2023's Avatar
Thank you.
Old Jul 25, 2016 | 10:12 PM
If it's making the noise only during those temps then it must be some sort of bushing.
Old Aug 6, 2016 | 06:25 PM
Civiccity03's Avatar
Damn that sucks, it sounds like the strut though? Why couldn't they just make cars that didn't clunk. Personally, rattles and clunks in a car are probably one of my biggest pet peeves. Nothing worse than driving a car that's making all types of funny noises.
Old Aug 27, 2016 | 11:01 AM
FG2023's Avatar
Thank you.
Old Sep 16, 2016 | 01:13 PM
FG2023's Avatar
Thank you.
Old Sep 21, 2016 | 02:19 PM
NickVR's Avatar
Please keep us updated on the situation.
I'm curious if they figure it out and how they treat you. Very unfortunate that still nothing.. at least they provided a replacement car in therror mean time. Seems after having it for 6 weeks they couldn't figure it out..
Old Sep 22, 2016 | 04:41 PM
FG2023's Avatar
Thank you.
Old Sep 24, 2016 | 12:11 AM
Sounds like you took a payoff/bribe to keep you from telling people how to fix their cars. Good job.
stevescivic
Honda Civic (2001 - 2005)
May 4, 2008 08:15 PM
thrasherx
Apr 12, 2007 04:39 PM
StRacer
Nov 24, 2003 04:06 PM
Roadrnnr
Sep 5, 2001 09:53 AM
